Why would the accumulator be hot? - FirebirdV6.com/CamaroV6.com Message Board
  • Why would the accumulator be hot?
    I recharged my AC last week, and the AC seems to blow cold at night, as well as off and on during the day. After about 15 minutes during the day it will start just blowing hot air. Sometimes turning it off then back on works. I have noticed that the big silver can(accumulator) is very hot. Any ideas on what may be wrong? I hear a very loud clicking noise coming from the clutch/compressor, do not know if this is normal. Both compressor and clutch seem to be functioning as the pressure on the vents seems to be strong. I checked for leaks with the uv die, and do not seem to find any.
    My Car <a href=\"http://members.cardomain.com/tucsoncamaro\" target=\"_blank\">http://members.cardomain.com/tucsoncamaro</a> <br />3 inch flowmaster catback system, with ceramic coated pacesetter headers,3 inch cat,K&N FIPK
    Re: Why would the accumulator be hot?
    sounds like you over charged when the heat of the day comes the pressures in the ac system get to high and the high pressure switch opens and wont let the compressor turn on
      What should the pressure reading be? I used the guage, and put it in the color that it stated. I believe it was no higher than 45.(25-45)
        6 days ago
