what weight/kind of oil in a rebuilt engine? - FirebirdV6.com/CamaroV6.com Message Board
  • what weight/kind of oil in a rebuilt engine?
    hey guys,
    my car is in the shop right now getting new pistons (020 overbore), rods, valves, oil pump, and all the gaskets. prior to this i have always used mobil 1 10w30, and now i was wonderind if i should change weights or brands after the rebuild. im also running a cam and planning on raising the rev limiter to about 6500, and im also spraying. feedback is appreciated [img]smile.gif[/img]
    later,<br />alan<br />1999 bright red v6<br />3800 series III<br />208\\210 comp cam<br />3000 stall edge tc
    I would stick with Mobil 1 10w30, but run a conventional (ie, non-synthetic) oil for the first few changes.
    Matt
    1998 Mystic Teal Camaro M5
      Originally posted by aalugo2000:
      hey guys,
      I am doing the EXACT same thing this weekend. I am going to use really cheap oil until the piston rings seat and oil consumption stabilizes. Then I will resume using precious, precious, Mobil 1.
      1999 red camaro v6 M5: with a turbo<br />13.52@107.99<br />No, seriously: Who Farted? <br /><a href=\"http://www.cardomain.com/memberpage/600086\" target=\"_blank\">http://www.cardomain.com/memberpage/600086</a>
        Use Mobil 1 supersyn oil 5w30...they're website says that you do not have to run conventional oil first on a new engine/rebuild that you can run their synthetic the first time
        1994 white Firebird M5<br />Flowmasters, CAI, 3.73s, LSD, coated pacesetters, eibach pro-kit, bilsteins, hurst shifter, JVC stereo, 18\" C5 vette wheels, Kuhmo Ecsta ASX rubber<br /><br /> <a href=\"http://www.cardomain.com/memberpage/744299\" target=\"_blank\">http://www.cardomain.com/memberpage/744299</a> <br /><br />Coming Soon: Turbo!
          Mobil1 is good oil, however their 30 is a little on the thin side. With Mobil I prefer the 0W40 european car formula, it works well in a 3800-II.
          2002 5-spd NBM Camaro
          Details: www.1lev6.com
            would it be bad to run castrol 10W40 on my engine instead of 10W30. I was thinking since I have almost 140,000 miles on her that thicker oil would be better. tell me if im wrong thanks
            96 Camaro 3.8 A4 Basemodel: 8 mm wires, Shift Kit, Hollowed <br />Cat(o2 sims), RKSport exhaust, IAT 5.6K resistor, Home Depot CAI<br />&gt;&gt;&gt;15.375 @ 89.27&lt;&lt;&lt;NEW BEST TIME <a href=\"http://www.cardomain.com/memberpage/552491\" target=\"_blank\">http://www.cardomain.com/memberpage/552491</a>
              thanks for the feedback... afew different opinions [img]graemlins/popcorn.gif[/img]
              can anyone give me the reasons as to why you would not start right off with the synthetic after a rebuild?
              • 2.8 Bird
                Good to see the site is back up
                by 2.8 Bird
                So there going to be anything new or update to the site since Bill is now the owner?
                I know there's still alot of interest in the fbody V6....
                3 days ago
              • FirebirdGT
                New Site Hosting Issues
                by FirebirdGT
                All - sorry but there seems to be some glitches from moving to a new Host - hopefully they will be fixed soon.
                If needed you can email me...
