pvc valve help - FirebirdV6.com/CamaroV6.com Message Board
pvc valve help
  • pvc valve help
    Ok i have a 1994 3.4l and got a replacement pvc valve thats a fram brand.
    But i dont no how to install it really without messing up my engine. Would someone want to write up a dummy tutorial on how to install these things. I no its on the driver side valve cover, but its pretty far back and dont no how to approach it.
    thanks
    Re: pvc valve help
    i no alot of you no how to do this. your just being lazy.
      Re: pvc valve help
      I'm not sure on the 3.4l but on the 3.8l camaros its just a plate that you unbolt and the pcv valve pops up. Swap pcv valve with old spring and put cover back on.
      Check out my cardomain site!<br /><a href=\"http://members.cardomain.com/99pewterv6\" target=\"_blank\">My Car</a>
        Re: pvc valve help
        well to replace a pvc valve you have to cut the pvc tubing and remove it then use couplers to attach up to the pvc piping. Now if you mean how to replace the pcv valve then it should just pull right out and pop back in.....
