help...rough idle still !! - FirebirdV6.com/CamaroV6.com Message Board
  • help...rough idle still !!
    Originally had SES code 305, cylinder 5 misfire. A guy on one of these message boards told me that
    the plug wires probably got arched by laying on the exhaust manifolds. So I got a tune up, new
    plugs, and replaced the stock plug wires myself with taylor 8mm wires. After I changed the wires,
    car started right up like normal but nothing seemed to change at all. The engine still idles rough
    and seems to lack power when I accelerate at higher speeds. Any ideas??
    mcG<br />aim=endlive<br /><a href=\"http://www.cardomain.com/id/endlive\" target=\"_blank\">97 firebird</a> ~ wrecked
    Did you ever get this fixed? having the exact same problem, just changed wires/plugs
      coil pack could be out
