HELP!! need advice/info/help! On Oil Pressure - FirebirdV6.com/CamaroV6.com Message Board
  • HELP!! need advice/info/help! On Oil Pressure
    okay, check this out. my oil pressure is really low at low RPM's. here's the actual numbers.
    ~600RPM 20
    ~1000RPM 40
    ~1200RPM+ 60
    what's the deal here? I don't think it supposed to be that low, sometimes it even drops down to around 10 at idle.......
    Justin96Bird / Justin98TransAm<p>1998 Navy Blue TransAm<p>Whisper Lid<br />free ram air<br />K&N Filter<br /><a href=\"http://www.hhbc.com/justin96bird/index.htm\" target=\"_blank\">DynoMouth Exhaust</a><p><a href=\"http://www.hhbc.com/justin96bird/index.htm\" target=\"_blank\">http://www.hhbc.com/justin96bird/index.htm</a>
    First off are you using a different oil (conventional to synthetic)? Also is the temperature high than normal? I say this because both have happened to me. When I switched to synthetic oil I could see a difference in pressure in the morning. I also noticed one day when I was running my car hard that the pressure was low but the temperature was about 210. When the car cooled down it was just like it had always been. Not sure if this is what's wrong with your car but thought I would tell you what has happened to me. Hope this helps. [img]graemlins/burnout.gif[/img]
    <a href=\"http://www.geocities.com/MotorCity/Street/6330/VicCamaro.html\" target=\"_blank\"><b>*1997 Silver Camaro A4/3.08*</b></a><br /><b>Best 1/4</b>(December 17, 2003)<br />Race weight: 3580lbs w/driver <br />RT: .396 1/4: 14.93 60\': 2.08 MPH: 89.73<br /><b>Mods</b><br />&gt;Flowmaster 80 muffler (muffler only) &gt;Homemade cold air with K&N 1000cfm cone filter &gt;Trans-go Shift Kit &gt;2400-2600 TCI converter<p><b>*1969 Camaro SS*</b><br />*502ci (92-octane pump gas)<br />*2-speed powerglide<br /><b>Best 1/4:</b>1.34 60ft 9.78@138.12mph (Aug 16, 2003)
      It might be your oil pump. My pressure was around yours with the exception of the 1200RPM (mine was lower) and when I was going to my buddies house to take the engine out the thing seized up. Now Im getting a new one, it might not be the pump but thats my guess.
      1996 Camaro 3.8L A4<br />*RK Sport Headers, RT High Flow Cat, B&B Tri-Flo Catback w/Quad Tips<br />*17\" Camaro SS Rims w/Firestone Firehawk SZ50 EP (275/40/17 Front, 285/40/17 Rear)<br />*SLP Speedometer Recalibrator<br />*American Sports Car SS Style Hood, Painted Green Disc Calipers and Drum Shells<br />*Charcoal Leather Interior
        nope, i'm still using dino oil just like always with oil changes every 3k. however it may have been the temperature thing you were talking about i'll have to double check. when you say it seized up on you, do you mean the whole engine, or just the oil pump, and if it was just the oil pump, how much was it to get a new one? Thanx.
