ok, little prob. here, today (i only did a couple of short trips), when i was in second, and i gavce it a little bit of gas, my car felt like it was being pulled back, and then the car would go like normal... whats the prob. here plugs and wires are new (althoug im not happy with them), and i also did a home depot CAI from the elbow- across and then down to a conical filter in the fender a couple of weeks ago..
thanks for any help
