i just recharged my ac and it is leaking out it seems to be coming from the rubber hose connetions but im not sure cus the dye is every where. what i would like to know is if you have had this problem where is the most likly place to leak so i can start there
AC recharged and now leaking somewhere, help
Re: input please
does it looks like it's leaking from the hoses hooked to the compressor? Usually, the compressor seal blows, and it just throws the freeon all over the motor when you run it. I put dye in mine when I had a blown compressor seal, and after two days of running the A/C, the whole front of my engine was covered in dye.~97 3.8L V6 Camaro~
A few things
Only Member of Team Hooker?!?
Re: input please
my input is make a more useful title next time so people that know answers to your problem can help you instead of "input please".
That doesn't help those that know the answers that can help you or people searching for a similar answer later on
Re: input please
Originally posted by RadRacerdoes it looks like it's leaking from the hoses hooked to the compressor? Usually, the compressor seal blows, and it just throws the freeon all over the motor when you run it. I put dye in mine when I had a blown compressor seal, and after two days of running the A/C, the whole front of my engine was covered in dye.
Re: input please
I paid $175 for all mine installed and charged. It helps if you know someone that works for the county that gets big discounts on parts :D That was compressor, orifice tube and condensor I believe.~97 3.8L V6 Camaro~
A few things
