friends lancer.... - FirebirdV6.com/CamaroV6.com Message Board
friends lancer....
  • friends lancer....
    my friends lancer is throwing a code (p0421) which is warmup catalyst efficiency below threshold.
    is that just a fancy way of saying that an o2 sensor went out?
    Re: friends lancer....
    sounds like possible cat conv. issues? Not sure how the lancer codes work though
    http://www.bowtiev6.com/
      i looked up some info on lancers and they have 2 o2 sensors, one before the cat and one after the cat.
      if the code says warmup catalyst efficiency below threshold (bank 1)
      what does bank 1 refer to? is that the sensore before the cat?
        check a lancer thread, better luck there. car manufacturers could change things up
        • 187shark
          by 187shark
