Dead computer? - FirebirdV6.com/CamaroV6.com Message Board
Dead computer?
  • Dead computer?
    Symptoms:
    Car cranks just fine but won't start.
    Fuel pump does not come on with key in 'on' position."
    OBDII scanner says "vehicle not responding" when properly hooked up.
    PCM BAT and PCM IGN fuses are fine. Power pins for PCM are receiving power. Computer possibly reset when negative battery cable was disconnected for 2+ hours. I think it may have shorted and died when I put the negative cable back on.
    Anyone have a similar screw up? How much would it be for a new PCM and the work to program it?
    That's what happened when I tried to use a 97 PCM on my car. I was just going to see if it worked so I could send it in to get reprogrammed some other time without having my car down for a long period.
    Same symptoms.
    Sam
    AIM: escalier deverre<br />\'02 Pearl Blue Metallic RSX-S (daily driver)<br />\'98 Black Firebird<br />98 V6 turbocharged to 02 LS1 swap<br />\'02 LS1/4L60E<br />LS6 Block, LS6 Intake Manifold, Thunder Racing 215/220 .600/.523/115 Cam, Titanium Retainers, Crane Double Valve Springs, 125 shot NX Wet Kit w/ NOS brand Purge, True Dual \"H\" Pipe w/ two chambers and dumps, 17x11(rear) and 17x9.5(front) Black Powdercoated ZR1 Replicas on 315 and 275 BFGoodrich Comp T/A\'s (Street)/ET Drags/Skinnies on Weldlites(Track), 3.42/LSD
