Headlights pop up when car is turned on! - FirebirdV6.com/CamaroV6.com Message Board
  • Headlights pop up when car is turned on!
    I have a 98 firebird... the headlights are popping up and ON whenever the car gets turned on... and the switch does nothing. Yes, I did a search on here... nothing.
    Any ideas what is going on? Is it the switch?
    Thanks. Im going to also post this in the other forum.
    <a href=\"http://www.cardomain.com/id/maleet\" target=\"_blank\">1998 Silver Firebird</a> <br />Basic mods... nothing real special but it sure looks good!<br /><a href=\"http://www.maleetpobanz.com\" target=\"_blank\">maleetpobanz.com</a>
    Re: Headlights pop up when car is turned on!
    its probably the gear inside the headlight motor. You can replace it with a stronger one instead. I know that sounds weird but does it make a grinding noise? When the gears wore down on mine, the lights would pop up at random and when I pushed the keyless entry.
    http://www.bfranker.badz28.com/headlightfix/index.htm
      :twak:
      Sounds like your light sensor is bad.
      1998 M5 3.8 Mystic Teal Camaro<br />Flowmaster exhaust, Pacesetter headers, 3\" cat, 3\" S-pipe, whisper lid, ram air, Spec Stage 1 clutch, Poly Trans mount, Walbro 255LPH. Numerous appearance mods.<br /><br /> <a href=\"http://www.cardomain.com/ride/2130533\" target=\"_blank\">http://www.cardomain.com/ride/2130533</a>
        I dont hear a grinding noise at all.
        I dont know if replacing the gear would do it- it doesnt have trouble or make noise going up or down. It does squeak but probably needs a lil grease but that cannot be the reason its doing what its doing. lol
        I cant turn the lights off because the switch is already in the off position... Ya know... I noticed the DRLs dont come on unless the switch is on P or headlights.
