I have a 98 firebird... the headlights are popping up and ON whenever the car gets turned on... and the switch does nothing. Yes, I did a search on here... nothing.
Any ideas what is going on? Is it the switch?
Thanks. Im going to also post this in the other forum.
<a href=\"http://www.cardomain.com/id/maleet\" target=\"_blank\">1998 Silver Firebird</a> <br />Basic mods... nothing real special but it sure looks good!<br /><a href=\"http://www.maleetpobanz.com\" target=\"_blank\">maleetpobanz.com</a>
its probably the gear inside the headlight motor. You can replace it with a stronger one instead. I know that sounds weird but does it make a grinding noise? When the gears wore down on mine, the lights would pop up at random and when I pushed the keyless entry.
I dont know if replacing the gear would do it- it doesnt have trouble or make noise going up or down. It does squeak but probably needs a lil grease but that cannot be the reason its doing what its doing. lol
I cant turn the lights off because the switch is already in the off position... Ya know... I noticed the DRLs dont come on unless the switch is on P or headlights.
