ac pulley clutch bearing - FirebirdV6.com/CamaroV6.com Message Board
  • ac pulley clutch bearing
    Ok so I can hear a loud clankign noise coming from the pulley system when I start my car. I'm 99.9% sure it's coming from the ac pulley since it starts and stops after something engages (sounds just like shifting). Do I need to just get a new pulley or is there more to this? Also, I need to know the baest place to get one (any place but the stealership)
    Car expresses who you are. If you have a ****ty car, you must be a ****ty person;)<br /><br /><a href=\"http://www.cardomain.com/ride/995979\" target=\"_blank\">http://www.cardomain.com/ride/995979</a>
    Re: ac pulley clutch bearing
    anyone???
      Before you go blaming the A/C compressor bearing, take the belt off and have a good look at more of the items in the belt rotation group, such as:
      1) Belt tensioner assembly for a worn or damaged piviot arm bushing.
      2) Idler pullies for seizing and/or wear.
      3) Alternator bearings.
      4) Harmonic Balancer pully isolation rubber degradation or seperation (Failsafe lug contact)
      Anyone of these items can start to make the noise that you described when the A/C is selected on and the compressor pulses are imparted into the belt group.
        Ok thanks, there are a few items I didn't check their (meaning alt bearings). I can tell you for sure, it has to be somethign with bearings and/or clutch for the fact it disengages.
          take off the belt and spin each pulley, see which one makes noise or doesnt feel right
            ok so more news, I just looked at it and I think I may be correct and have to replace the whole pulley. The clanking sound starts up again after I turn the ac off and then when I turn it back on, it stops after about 2-3 seconds (the noise stops that is).
              Another update:
              I replaced the ac pulley and it fixed the pinging. I decided to look furthur into my car and noticed my coolant was getting kinda old, so I replaced that. Now the only thing left is royal purple ATF, royal purple oil, and replace brake fluid
                Mines bad too, it makes a squeaking sound. I just keep the climate control on vent and theres no noise only at startup for like 5 seconds.
