I just used my OBDII scanner on my 2000 Camaro and it stated that there is a Cylinder 3 Misfire detected. How do I fix this, and how much will it cost? I also just had my plugs and wires changed.
Problem code P0303?
Re: Problem code P0303?
Check to see if that wire isn't touching your exhaust.<a href=\"http://www.fbodyelpaso.org\" target=\"_blank\">www.fbodyelpaso.org</a> A4 stock 3.42 and LSD not Y87,SLP cold air induction, whisper lid, k&n filter, flowmaster 80 series, hypertech, 160 powerstat thermostat, t/a front bumper, functional nostrils, pacesetter headers best et: 15.9 at about 4800ft
the number 3 wire. Or you couyld swap number 3 with another and see if problem follows. Wire could have been damaged on the install, or you could have a coil going bad, or maybe even the ICMOriginally posted by kalaI'll have buttsecks with Richard Simmons!
TEAM BLACK!!!
parting her out
