Bouncing Idle - FirebirdV6.com/CamaroV6.com Message Board
Bouncing Idle
  • Bouncing Idle
    I tried searching this but i didn't come up with much useable info. I have a 01 3.8 Manual tranny every time i switch into neutral (stop lights, coasting to a stop) the idle bounces from like 400-1200 and sometime when i throw it back in gear it'll bog real bad if i catch it down in the 400RPM range its only stalled me once but its becoming worse and more annoying. Has anyone had this trouble before or know of it and know how to fix it. Thanks for the help guys/girls
    This is kinda like lizzardfire problems but not sure if its the same my fuel filters fine i cleaned my MAF sensor, mods if u wanna throw this post into his thats fine just not sure if its the same problem
    Re: Bouncing Idle
    Hello I am new to camaro's but I had a 1997 Chrysler Sebring that was doing something simular to that and it was the EGR vavle there is a way to check but I am not exactly sure on how. Good luck I know that sucks first hand.
      Re: Bouncing Idle
      happened in my automatic....let me ask you something....when where the wires and plugs changed last?
      1998 Red T-top V6 Camaro
      - K&N Filter, Pacesetter Headders, MagnaFlow 2.5" Hi-Flo Cat, FlowMaster 80 Series, PowerDyne Supercharger@9Psi More 2 Come
        Re: Bouncing Idle
        I just did a full tune up including plugs and wires no more then 300 miles ago and i check those casue i figured maybe a wire was arcin off othe manifold. i don't hear any ticking sounds that would lead me to belive it was a plug/wire. Can anyone clear up the EGR valve possibility. I had the egr valve go bad in my s10 bud it raced and it didn't bounce.... If anyone could clear that up i'd greatly appreciate it. Thanks for the help from the 1st two posters
          6 days ago
