High mileage = tune up - FirebirdV6.com/CamaroV6.com Message Board
  • High mileage = tune up
    Well I'm currently sitting at 140k + and the car is not acting up at all. But just like any other person knows... soon something will go wrong.
    School starts in a few weeks and with work and such, there will be no time to work on the bird. In the past month I've changed the oil, flushed the coolant, cleaned the K&N, changed tranny fluid, bought new tires, and today I changed the rear differential fluid to synthetic and cleaned up the cover inside and out. My question to you guys... what else should I do before school starts? Remember that I am in an apartment complex, have 2 jacks, and one toolbox... so it needs to be something somewhat simple and not time consuming. Thanks in advance!
    Seafoamed about 2 months ago as well
    Welcome future UK stars... Darius Miller, Deandre Liggins, Kevin Galloway, Josh Harrellson
    Re: High mileage = tune up
    I'd say u have most of the basic things covered. IF you want, I would check for leaks and any broken seals and worn suspension parts. Also, check your serpentine belt for cracks/wear and also you could change the ps fluid and brake fluid. The brake fluid is supposed to be changed out once a year or every 12k. Just something to keep in mind
    Car expresses who you are. If you have a ****ty car, you must be a ****ty person;)<br /><br /><a href=\"http://www.cardomain.com/ride/995979\" target=\"_blank\">http://www.cardomain.com/ride/995979</a>
      check belt maybe grease some bushings in the suspension
        take it to have plugs wires and coils done
          why would he take it somewhere. just do that yourself. with a basic tools it's do-able
          WAWA-A-HOLIC
            fuel filter
              maybe he doesnt have the ability? or a jack/ramps? idk
                thanks guys... I planned on doing the fuel fuilter next week and maybe plug wires. Brake fluid is something I need to do as well.
                I will note that after flushing the coolant and changing gear fluid I gained 3mpg. I drove to the parents with cruise control on both times and saw a 3 mpg difference after doing both.
