L67 rebuilt with SSMS head and Cam - FirebirdV6.com/CamaroV6.com Message Board
  • L67 rebuilt with SSMS head and Cam
    Can this be done?
    [ March 19, 2002: Message edited by: mike24 ]</p>
    Silver 2000 Firebird A4<br />3.8 A4<br />14.746 @91.98 Feb /03/02<p>1990 Mitsu GSX 5Spd I just got it.<p>Otis for President 04 !!!!!!
    Well no, in a way. You have to use L67 heads and not L36 heads. I bet that you could send your L67 heads to tom @ SSM and he might work on them. but the heads are different, they have their injectors in a different location then the L36 heads do. The cam could work though :D
    1996 Y87 Camaro, 175.0 rwhp, 211.6 rwtq.....1/4 15.500@88.54 &lt;----- Needs work!!<br />-CAI, Custom bent S-Pipe, LS1 I-Pipe, Flowmaster 80 series, !MAF, manual fan switch, relocated trunk pop switch, 180 degree t-stat, More to come!<br /> <a href=\"http://camaro.wbisolutions.com\" target=\"_blank\">http://camaro.wbisolutions.com</a> <p>WANTED!!! Naked and handcuffed!
      What are you tryin to do?
      If you use L67 pistons/rods sure.. if you plant o use the L67 blower then you need L67 heads..
      you could still use the SSM heads/cam.
