Front DRL lamp replacement - FirebirdV6.com/CamaroV6.com Message Board
  • Front DRL lamp replacement
    OK you all have helped in the past how do you replace the front turn signal lamp/DRL on a 2001 firebird.
    Hopefully some one know how to do this.
    &gt;&gt;OH 1 FIREBIRD SunsetOrangeMetalic<br />Not at All Stock
    Re: Front DRL lamp replacement
    Much easier than you may think. Look under the vehicle, directly under the DRL you need to replace. There should be two 10mm bolts, that hold something thats like a door, closed. Then reach in the hole and feel around until you find the plug. Feel around the plug, there is a tab that you must press before you can turn it. Once you do, turn it then pull it out through the hole and replace your bulb. Good Luck!
