WTF, brake lights are lit when headlight are on!?!?!
i have heard of cars computers doing weird stuff... windshield wipers and lights turning on spontaneously when their battery is going bad. also you make have an electrical short.
1998 Onyx Black Camaro A4 2.75\" Custom Flomaster Catback, Removed Cat, MTI Lid, Jet Power Programmer, K&N air filter, 1LE aluminum driveshaft, maf screen removed.
check to make sure you have the right bulbs in there... I had an 88 s-15 jimmy that did the same thing the previous owner had replaced the brake lights with the wrong bulbs I drove it for a few weeks before I noticed
-Brad
2000 V-Star Custom 1100
:rock:
ACTUALLY...you might wanna check to see if the tailight sockets are burnt or melted. Its a common problem among the older firebirds and camaros. There was actually a bulletin about this at one time. Ive replaced a couple sets of sockets to correct incorrect lighting of tailights. Sometimes they just dim out. sometimes they dont work. Sometimes only half work. You're problem could be related. SOO check the sockets up close inside and out.
Take the bulbs out, rotate 180* and reinstall. If you put them in 180* out, they will stay bright. Check that first...dual filament bulbs are weird like that. I had the same problems a few years back and found out it was wrong installation.
