what's the latest on your project? how far have you gotten so far and have you run into any problems?
hey Magnus How 'bout an update on the heads and cam
ya u break anything yet :D<a href=\"http://www.pbase.com/danny83/car_pix\" target=\"_blank\">http://www.pbase.com/danny83/root</a><br /><a href=\"http://community.webshots.com/user/ttopbird96\" target=\"_blank\">http://community.webshots.com/user/ttopbird96</a> [/URL]<br />00 NMB Formula M6<br />323.4HP, 336.5TQ<br />Lid, Filter, Cutout, all else stock :)<p>\"Let the modding begin!\"
I have taken LOTS of pics.... [img]smile.gif[/img] I am also writing down everything I'm doing to make an install guide.
Nothing broken yet.
Removing the crank bolt was a PITA.. that thing is on there TIGHT.. then removing the crank is a PITA as well.. I went to autozone and rented a harmonic ballancer pulley puller.
So far this is off the car:
Intake itself
Both intake manifolds
Alternator
Tensioner Bracket
Coil Packs
coolant is drained..
I just have to remove the valve covers now, pull the heads.. remvoe the water pump, front cover and swap the cam. lol
I'll probably take tommorow off to finish up.. So far I've just had 4 hours a day, and I just started yesterday night.
I'm hoping to dyno on saturday as well so I'm tryin to hurry up.
I ordered GM head gasket kit, head bolts, rocker bolts, front cover gasket and timing chain ... and I also ordered felpro exhaust manifold gaskets from Autozone.
I'll hopefully have pics on my webpage monday.
- KeithKeith - Chicago<br /><a href=\"http://www.hptuners.com\" target=\"_blank\">HP Tuners - PCM Reprogramming</a><br /><a href=\"http://www.dxsoftware.com/magnus/\" target=\"_blank\">97 Firebird V6 to LS1 swap</a><br /><b>V8 9.967@132.78</b> 1.322 60\' NA Heads/Cam<br /><b>V8 10.295@128.48</b> 1.363 60\' NA Cam Only<br /><b>V8 10.987@119.31</b> 1.422 60\' NA Stock Internals<br /><b>V6 13.674@98.22</b> NA<br /><b>V6 12.394@104.91</b> N20 100HP
What kinda gain u lookin to get??Past Ride
1995 Firebird A4 3.8 Turbocharged -- 12.50 at 108
(If you dont know me, you haven't had a V6 long enough)
Current Ride
2006 Mitsubishi Evolution GSR
www.myspace.com/shane1015
Not sure how much I'll gain.. I'm hoping for 30 rwhp.
THe car is on jack stands right now so I could get to the converter.. I'll probably pull it off the stands cause it is a pain to leen over it when its up there.
I'm also gonna leave work early today and try to finish up tonight. TOmmorow its supposed to be even colder and I really HATE working on my car in the cold.
The high for today is 45.. tommorow its around 30.
I have a small heater but it doesn't heat up my garage to a nice 72 degrees. :(
I also need to get pushrods.. I bet the cam base circle has changed and my heads are milled .020".. I'll go with a 210* chromoly 1 piece rod.Keith - Chicago<br /><a href=\"http://www.hptuners.com\" target=\"_blank\">HP Tuners - PCM Reprogramming</a><br /><a href=\"http://www.dxsoftware.com/magnus/\" target=\"_blank\">97 Firebird V6 to LS1 swap</a><br /><b>V8 9.967@132.78</b> 1.322 60\' NA Heads/Cam<br /><b>V8 10.295@128.48</b> 1.363 60\' NA Cam Only<br /><b>V8 10.987@119.31</b> 1.422 60\' NA Stock Internals<br /><b>V6 13.674@98.22</b> NA<br /><b>V6 12.394@104.91</b> N20 100HP
hey Keith,
If you want a heater, i have a keroseen (sp?) heater.(actually its kevin's, my buddy w/ the grand prix gt) I use it during the winter after i wash my car and everything freezes. You'd be surprised how well that damn thing heats! you might as well wear shorts and a t-shirt cause it gets hot [img]smile.gif[/img]
Drop me an email or something and let me know, just incase u fall behind and HAVE to work in the cold [img]smile.gif[/img]
Good luck
[img]graemlins/thumbsup.gif[/img]<a href=\"http://www.pbase.com/danny83/car_pix\" target=\"_blank\">http://www.pbase.com/danny83/root</a><br /><a href=\"http://community.webshots.com/user/ttopbird96\" target=\"_blank\">http://community.webshots.com/user/ttopbird96</a> [/URL]<br />00 NMB Formula M6<br />323.4HP, 336.5TQ<br />Lid, Filter, Cutout, all else stock :)<p>\"Let the modding begin!\"
Danny, thanks for the offer! I have 3 electric space heaters now that seem to be doin the job.. I just have to make sure they are on different circuit breakers. lol. I'll call you if they fail.
12 hours into the install........
New camshaft is on the car, timing chain is on and aligned (Its sooooo damn easy).
headers are unbolted.
1 head is off the car. (Gasket went with it! YAY)
I have to cut my y-pipe somewhere because my headers are welded to it and they are not falling down far enough. *sigh*
Tonight I'm going to buy some strong chromoly pushrods. (The ramps on the COMP Cams cam is pretty fast, I don't want to risk stock rods).
I'll bolt up the front engine cover really quickly, cut the y-pipe.. drop the manifolds down a little more out of the way..
gasket match my lower intake to the heads..
Tonight I will be happy if I have both heads on the car.
I have taken over 200 pics so far. :eek:
<blockquote>quote:</font><hr>Originally posted by camaro_zach:
holy crap, 200 pics! good luck keith, i cant wait to see the pics and read the install. Good luck.<hr></blockquote>
Awesome Keith!
Hey Zach, did you get that email I sent you asking about the Tracking Number on the package you sent me last week? J/W
keith, i amire and respect the knowledge you have on our cars. i am the kind of guy given a bolt i WILL strip it. just my bad luck. God did not make me mechanically inclined, just good looking. j/k ;) if it makes you feel better, i just spent $1000 for the power pack install. sometime in my lifetime i hope i can realize i just saved 1 grand.
keep up the awesome work and let us know those numbers as soon as you get them.
nino6s.......under the hood or under the belt, they just dont cut it.
Thanks guys....
Day 3....
Yesterday I ordered 7.000" Trickflow chromoly pushrods to stand up to the agressive lobes of the COMP Cams XE camshaft..
I had to cut the y-pipe a little, not completely, just enough so I could flex my headers down.. worked VERY well.
1 head is on the car and bolted up.. second head is unbolted, just need to pull that, clean the surface and bolt holes and install new head..
Front cover is on.
Maybe I'll get done tonight *shrug* It was FREEZING yesterday so I didn't work long.
is the install article going to be posted on your website or on fbv6. this is good stuff.
i'm going to be ordering a powerpack soon and i want to install it myself. hopefully i can do it with this guide..97 CAMARO RS<br />12.9@103mph<br />best 60ft..1.9 ( on street tires)<br /> 1.7 (on gas)<br />turbo supra 12.5@119mph (street tires)<br />new times to come sporting the sp63gt
firebirdv6..
I'll put up another album on my site though..
I really need to update my site.. *sigh*. there is so much info I want to add.. especially Magnus FAQ. I hope I get around to it soon.Keith - Chicago<br /><a href=\"http://www.hptuners.com\" target=\"_blank\">HP Tuners - PCM Reprogramming</a><br /><a href=\"http://www.dxsoftware.com/magnus/\" target=\"_blank\">97 Firebird V6 to LS1 swap</a><br /><b>V8 9.967@132.78</b> 1.322 60\' NA Heads/Cam<br /><b>V8 10.295@128.48</b> 1.363 60\' NA Cam Only<br /><b>V8 10.987@119.31</b> 1.422 60\' NA Stock Internals<br /><b>V6 13.674@98.22</b> NA<br /><b>V6 12.394@104.91</b> N20 100HP
by Andy HHey everyone! I've been trying to remove my transmission for two days now! I need to replace the clutch. Only thing I've got left holding the transmission...4 weeks ago
