When im driving, myoil pressure guage changes. WHile stopped. itll go to about 30, but when i push the gas itll shoot up to around 60, and when im coasting, itll jump between 40-50. is this normal. Its a 98 bird with 118000 miles.
Oil pressure question...
Re: Oil pressure question...
Originally posted by AlmondRoccaWhen im driving, myoil pressure guage changes. WHile stopped. itll go to about 30, but when i push the gas itll shoot up to around 60, and when im coasting, itll jump between 40-50. is this normal. Its a 98 bird with 118000 miles.
If you're really concerned that you'r getting bad readings, you can find a new sender (aka sensor) at a local auto parts store for not very much money. Be careful. I fouhnd 2 ddifferent models in my search. One was pretty cheap (~$10 - $15), the other was somethng like $50. I can't re4member the brands though, sou you'll have to do a bit of calling around or googling just to be sure.1997 Camaro, Y87 Perf. Package, iRotor Drilled & Slotted Brakes, Bilstien Shocks, Custom drive shaft, K&N Filter, & Mobil 1 synthetic. 202+K miles and still drives like new.<br />-If you can\'t stomp \'em in the straights, kill \'em in the corners...
Originally posted by cam98aroyes, it is normal.. higher rpm=higher pressure, its simple.
your oil pressure should be at 60 at 2k RPM
the more the engine is turning then the more pressure the oil is experiencing... if the pressure is low at higher rpms or below 20 at idle then you will have a problem... but your fine.
I have a 95 Maro with a 3.4 and at full operating temperature I idle at 10 psi and hovers around 35 till 2K where it rises to 40 pounds. When cold it reads constant 45.1995 Arctic White Camaro. 3.4L/A4<br /><br />\"Stupid men make mistakes, wise men learn from mistakes\"
Originally posted by iZZZ!mine used to bounce like that too, until the lil membrane on the bursted, forcing me to get a new one. easy fix
on the what?
I might want to fix mine. My oil pressure is showing a bit normal than it used to. It really bugs me.1999 Camaro V6 3.8L A4<br />Red, T-tops, Monsoon<br />No mods.......yet.
