check engine light - FirebirdV6.com/CamaroV6.com Message Board
check engine light
  • check engine light
    i have the following codes that come up in my car and i dont know what they are and where to start fixing them. 1870, 1441, 1406, 1441 again. so can someone please help me and tell me if these are common codes, and maybe how to fix them...
    Re: check engine light
    P1870 Transmission Component Slipping
    P1441 Evaporative Emission (EVAP) System Flow During Non-Purge
    P1406 EGR Valve Pintle Position Circuit
    clear the codes, and see which ones come back.. you may have just got a freak code every once in a while.
    once you get the ones that came back, tell us which ones they are
      ok well got my car scanned again im throwing a p1441 code which is Evaporative Emissions (EVAP) system flow during non-purge how do i fix this i have to fix it asap cuz i have no registration...
        you either have a bad purge valve, or your evap canister is clogged or whatever
          yeah i need to know how to fix it. where the evap canister is and where the purge valve is...
            not sure, but i THINK its on the left side of your engine by the valve cover
