Air blows warmer / Car looses power - FirebirdV6.com/CamaroV6.com Message Board
  • Air blows warmer / Car looses power
    For the last week when I'm driving on the highway, my air conditioner will suddenly start blowing noticeably warmer air and the car will loose power. It doesn't feel like it's missing a cylinder and I'm not getting any codes, but it definitely goes sluggish. It only does it for a few seconds, then the air is instantly cold again and the car runs fine.
    2000 3.8 - Any ideas?
    Lounge Moderator
    Re: Air blows warmer / Car looses power
    I'm thinking that your air condition compressor might be seizing up which would explain both the loss in power (dragging down the engine) and the loss of cooling.
    Any weird noises and such?
    It's either that, or you have an electrical problem that is disengaging the A/C clutch as well as affecting some system that gives you the engine power loss, like fuel pump or ignition. What is your volt gauge doing during these events?
      Sounds like what one of my cars did. The clutch on the compressor was locking up while it was working thus quitting and blowing hot air. Easy way to tell is have someone rev the engine a little and watch the compressor you'll see if it's seizing or not.
      Let's flip a coin. Heads I get tail, Tails I get head.
        No noises at all. I would think a seizing compressor would cause the belt to slip more that dragging the engine down, but I'm unsure.
        The voltage gauge don't change.
        There is one thing the car has always done. Any time I'm at a dead stop and punch it, the air blows warmer. Even though the air warms, it doesn't feel like there's any more loss of power than one would expect to experience with the air on.
        Let me guess... a compressor is ungodly expensive. It's 100+ degrees here; don't need to have the air go out now.
        Lounge Moderator
          It may not squeal that much mine didn't. I believe, maybe not all years, there is a automatic shutoff under full throttle to give better performance. IDK though. Not sure on the prices just jump on Autozone or something and see.
            You got that right, it's probably the worst thing that could happen to your ac. Getting it charged and/or fixing a leak (usually gasket or hose) costs nothing compared with getting a new compressor installed. It's like $300 for the thing and then however much the average mechanic is going to rip you off for, I know that a major chain is going to want an arm & leg for this. You may be better off finding a no-name shop that someone you trust recommends (ask your friends!) if the compressor blows.
              I checked it out last night. It appears the compressor is running smooth; I could see no evidence of seizure.
              Lounge Moderator
                Good, cause I just had to replace the A/C compressor on my Bonneville and I got quoted at $765 for the repair and recharge, my cousin works there and that is even with his parts discount. What the @#$%?? So I said to hell with that, got a compressor off this guy I know in town that is a huge pack rat for $180, and did it myself. Gotta love it.
                  Don't go by just watching it while its running. The internals of the compressor might be ok, but the bearings that support the clutch might be on the verge of packing it in.
                  Remove the belt and with your hand roll the 2 parts of the A/C clutch over. First do the outer clutch (the part with the pully) and then do the inner driven assembly (thats the part that doesn't rotate when the Air Conditioning is not turned on). They should both rotate smoothly with no roughness, grabbing or noise.
                    6 days ago
