ok on my car the speedo is way off. I will be going 60 and the car says im 90. my abs light is on. and my praking brake is always on even when i take it off. the car is a 93 3.4 t5 thanks guys
got some problems
Re: got some problems
have you upgraded the gears at all? if so that would put the speedo off.
Follow me!
Or this
as for the abs light, first check your third brake light to see if the bulb is burnt out. if it is replace it and it will shut the abs light off..
if its not the bulb in the light, have your wheel sensors checked.
as for the ebrake light.... id say its another sensor.
Follow me!
Or this
Originally posted by vanbibberas for the abs light, first check your third brake light to see if the bulb is burnt out. if it is replace it and it will shut the abs light off..
where is the sensor for the ebrake
lets put it this way you car probably has numerically taller gears i.e. 3.73's and the reluctor ring was probably never pressed back on when teh gears were installed so thats why the ABS light stays on, thats my problem but youd e have to oull the rearend cover to tell either way
76 Camaro Rally Sport-355/TH350- Soon to be LT1/TH350 with a little laughing gas to wake it up...;)
89 Ram D350 CTD/M5- 1 Ton Dually getting 27 MPG's
maybe. thats not always the case though. our cars are getting old and things break. id put money on it being a sensor gone bad. its a pretty common thing with these cars.
Follow me!
Or this
