got some problems - FirebirdV6.com/CamaroV6.com Message Board
got some problems
  • got some problems
    ok on my car the speedo is way off. I will be going 60 and the car says im 90. my abs light is on. and my praking brake is always on even when i take it off. the car is a 93 3.4 t5 thanks guys
    Re: got some problems
    do you have the right size tire/rim combination?
      have you upgraded the gears at all? if so that would put the speedo off.
      Follow me!
      Or this
        as for the abs light, first check your third brake light to see if the bulb is burnt out. if it is replace it and it will shut the abs light off..
        if its not the bulb in the light, have your wheel sensors checked.
        as for the ebrake light.... id say its another sensor.
        Follow me!
        Or this
          idk i just bought the car how can i tell?
            yes the light is out i wil check on that
            where is the sensor for the ebrake
              My ebrake light was kept coming on for about 2 months while I was driving but it just quit coming on and went back to normal and been like that for about 3 months now. I would not worry about it if it is not engaged.
                Look at the wheels, they should be 235/55/16, 245/50/16/ or 275/45/17 (unless theyre 18's then I dunno what the size would be) if they're not there is your reason.
                  lets put it this way you car probably has numerically taller gears i.e. 3.73's and the reluctor ring was probably never pressed back on when teh gears were installed so thats why the ABS light stays on, thats my problem but youd e have to oull the rearend cover to tell either way
                  76 Camaro Rally Sport-355/TH350- Soon to be LT1/TH350 with a little laughing gas to wake it up...;)
                  89 Ram D350 CTD/M5- 1 Ton Dually getting 27 MPG's
                    maybe. thats not always the case though. our cars are getting old and things break. id put money on it being a sensor gone bad. its a pretty common thing with these cars.
                    Follow me!
                    Or this
                      are the sensors hard to change? and are they on each wheel?
