shift light installation - FirebirdV6.com/CamaroV6.com Message Board
  • shift light installation
    has anyone installed a shift light on their 98 firebird? Need some help here- could someone bring me through the connecting of the light to the tach wire... which wire is it? etc...
    thanks!
    Nate
    98 firebird, black, flowmaster dual exhaust with 4 1/2 inch diameter chrome tips, 17X10 boyd coddington smoothie II wheels, hurst shifter, whisper induction lid.
    The tach wire is easiest to get to on the passenger side floorboard. There is a connector which has a white wire that is the tach wire....I will post the other colored wires in the connector tonight when I get home to look at my service manual.
      So basically, it's the white wire under the passenger side panel for RPM?
      Anyone else with a comment - PLEASE!
      Thanks
      Nate
        speedy-v6-camaro's wire sounds easier to get to then where i installed it. i installed a tach with the shift light, and ran the tach wire to the ignition control module, pin E. this wire was pretty hard to get to, so i say try speedy's first. by the way speedy, where'd u connect the ground to? i have it near the gas pedal and sometimes for wahtever reason it seems as the ground is not making good connection because the needle will freeze for just a moment (even though the shift light is always dead on).
