Batch firing the injectors - FirebirdV6.com/CamaroV6.com Message Board
  • Batch firing the injectors
    Has anyone ever built a circuit that could be used to batch fire the injectors? I think a simple circuit where the PWM duty cycle could be adjusted might prove very handy when troubleshooting and the computer is failing to send the signal to fire the injectors.
    I'm running in to a problem with a new motor I'm installing. The engine will start and run for a few seconds and then quit. From what I've read in the service manual the injector signal stops after 2 seconds if the Fuel Enable signal is not present at the PCM.
    I'd like to hear from anybody that may have had similar issues. Thanks this forum is really useful.
