96 Camaro 3.8 dies after driving ~3 hours!! - FirebirdV6.com/CamaroV6.com Message Board
  • 96 Camaro 3.8 dies after driving ~3 hours!!
    Hey y'all--
    My kid has a 96 Camaro 3.8 5-speed, all stock except a Flowmaster (and possibly a 180* thermo). I bought the car as a non-running project (it sat for several years) and we just got it on the road Monday.
    The car has 77K miles. New parts before getting it on the road include:
    plugs (AC Delco Rapidfire/Irridium/whatever/$4 each)
    wires (MSD)
    front O2 sensors (Bosch)
    fuel pump - complete assembly w/ pickup & sender (Carter iirc)
    Purolator fuel filter
    drained gas tank, filled with new gas
    New parts installed trying to fix the problem:
    TPS (Delco)
    New parts being installed today:
    Water pump (Delco)
    195* thermostat (Delco)
    Radiator cap (Delco)
    Radiator hoses
    Heater hoses
    It runs perfectly, until we've been driving ~3 hours, then it won't accept any throttle (push the gas, doesn't rev), runs crappy, then dies. After turning off the key and sitting for a minute, it starts right up. It may run fine for 15 minutes or 15 seconds, then does it all over again. I had to restart it probably a dozen times monday night trying to get home, and when it ran, the idle speed was ~2200 RPM.
    The ~3 hours driving is mostly around town, running errands, a little bit of highway, just making sure the car is OK and teaching him how to drive a stick. Like I said, the car runs flawlessly, right up until it quits. The gages read normal. It shows P0122 on the code reader, which is TPS.
    I replaced the TPS with a new AC Delco Tuesday, and went for another long drive. It quit again after ~3 hours the same way. Required several re-starts to get it home, but this time the idle speed was normal. Again, it shows P0122, but I'm thinking that disconnecting various sensors (including the TPS) while trying to find the problem may be falsely setting that code. But that's the only code it has.
    I only had time to drive about 90 minutes Wednesday night. Nothing went wrong. Had a fuel pressure gage taped to the cowl and, when running WOT thru the gears, the fuel pressure dropped to ~18 midway thru 3rd. I’ve got a new Delco fuel filter for it; that goes in today. I plan to install a new fuel pump relay. I’ve been told I should have bought an AC Delco fuel pump!
    My kid drove the car a bit on Thursday with no problem again.
    I probably should have dropped the tank and had it cleaned, but instead I used the trapdoor method of fuel pump replacement. I'll open up the trap door again and look at the fuel strainer, and probably get the tank cleaned once we run the gas out of it.
    I haven't found the fuel pressure regulator either. The Haynes manual has photos of a 3.4 and an LT1, but no 3.8. Where is it? At this point, I’m thinking the FP is regulated by the computer via variable pump voltage…
    The cooling system wasn’t maintained, and is full of sludge. The radiator cleaner I poured in seems to have cleared out the crud that was holding the water in the water pump, and now it leaks freely. I got a new water pump, radiator cap and 195* thermostat (all Delco), plus new radiator hoses and heater hoses.
    The temp gage shows 180* when warm, which makes me pretty sure the car has a 180* thermostat, so I better find the ECM and check for an aftermarket chip. I’ll put it back to stock if it’s been changed.
    I haven’t found any wiring that is worn thru or eaten by rodents. Will keep looking.
    Someone suggested a new intake air temp sensor. Other suggestions were a bad gas cap, and to spray “Component Cooler” on electronic items when the problem occurs.
    After I put the car back together today, I’ll drive it until it quits again. I’ll have the fuel pressure gage taped on, so I can tell if I have a fuel problem. I’ll take off the gas cap and see if it fixes the problem. If not, I’ll disconnect the intake air temp sensor and drive it again. If it still quits, I’ll disconnect the MAF and see how it does.
    I’m REALLY HOPING someone here has experienced this and fixed it!!
    What do y’all think?
    thanks!
    kevin
    Re: 96 Camaro 3.8 dies after driving ~3 hours!!
    (1) Don't put in a 195, use a 180. These engines run HOT.
    (2) There are NO chips or programing available for a 96. A 97 can be swapped in, which can be programmed. But the PCM may have problems due to sitting. Check the PCM connections for damage.
    (3) Use Dex-cool 50/50 mix. Add some DISTILLED water if you want to lower the ratio. More is NOT better with Dex-cool. People use too much like the junk green stuff. Dex-cool really is a better coolant.
    Raven
      Thanks! Turns out the thermostat was a 195 already, so I need to figure out why the gage reads 180....
        thermostats arent 100% accurate, and neither are the gauges
          i have a 96 3.8 camaro and had that same exact problem. i took it to the mechanic and i found out that the fuel pumps went bad and got them replaced. after that it ran like a champ
            I have successfully duplicated the problem while having a fuel pressure gage attached! The fuel pressure drops to ~10. This is with the rusty gas tank nearly full, a new AC fuel filter, the Carter fuel pump, and the original relay. It happened while accelerating onto I-75;
            I shut it off on a roll, coasted in the shoulder for a bit, restarted and was able to keep the car running with a feather foot in 5th gear. After 5 minutes or so, the pressure started creeping back up. When it hit 20, the car ran pretty well, and eventually returned to normal.
            So the plan is:
            1) new tank (or possibly clean old tank) and AC Delco filter- if that doesn't help,
            2) new relay
            3) new cap
            4) new AC Delco pump
            What's that gas tank site? Gastank.com or something? Anybody buy there?
            Thanks everyone!
              if you just want to replace the tank find a junkyard and get one out of an 02 v6, it should be plastic, and you'll go from a 16 gallon to an 18.
              It sounds like there is crud getting sucked either into the pump or the filter. I'd pull the filter with some thing to catch what's gonna come out of the fuel tank side and see what falls out.
              I think the time issue is irrelevant, your feathering the throttle is shifting whatever is rattling around either in the filter or in the pump itself.
              Of course these are my theories trying to diagnose from the opposite side of the planet. I'm abut 90% sure on the newer fuel tanks being plastic like the v8's.
              -Brad
              2000 V-Star Custom 1100
              :rock:
