Car hasn't started in almost two weeks. Last night it finally started and I drove it around until it threw a code. Code was for the Crankshaft position sensor, Can anyone give me any information on where this is and if it's a simple sensor change? I have a '97 3.8. Thanks!
I believe it is located on the front lower center of the block. It should screw right in. It's around the front pulley and has a wiring harness plug on it. I believe it's behind the harmonic balancer.
\'97 Camaro M5 Y87 3.23 LSD, homebrew CAI, highfloCat, Flowmaster catback, Pacesetter headers, specstage3 clutch and aluminum flywheel, !egr, 2kW system.<br /><br />Possible L67 bottom end w/ abbott heads and a turbo in the works... gotta do more homework
Thanks a lot guys! I'll be happy as hell to get this thing running right again! Car has been out of commission for almost 3 months now with different problems.
