i've had this problem since i got the car in june. it's usually on and off, and i've learned to live with it haha. but once in awhile, when i turn the car key back to turn the car off, it'll turn back but not back enough to get the key out. then i'll try to play with it and it won't move at all. then i'll play some more and an act of god seems to let it come out. anyone else have this problem?
key gets stuck in ignition
When you can't get your key out, check to make sure your auto gear shift is locked into place(ie try to pull it out of park without pressing the lock button) The locking mechanism sometimes gets stuck and doesn't go down.If the gear shift is'nt locked in park, your key won't come out.95 Camaro 3.8L Y2K motor <br /><a href=\"http://www.cardomain.com/id/coriya71\" target=\"_blank\">www.cardomain.com/id/coriya71</a>
by ssms5411Had to be evacuated Monday again after a fire was going on the hill behind us. Only 3-4 hours, they did a good job getting it under control. Especially...2 weeks ago
