ac turns car off - FirebirdV6.com/CamaroV6.com Message Board
ac turns car off
  • ac turns car off
    so this is how it began, i bought one of those ac recharge cans and used it on my camaro. i've done it before on other cars and its worked however that was not the case with mine. after i recharged it i put the ac on low and drove to work. the car was running fine and i decided to mess with the ac while i was stuck in traffic. i put the ac on full blast and the air was coming out warm as usual and then i put i moved it from ac to max and then the car turned off. i turned the ac off, put the car in park and then turned it on again and continued waiting in traffic. when i got to work i turned the ac on one more time and it shut the car off again. any idea what could be going on? its not that big of a deal because i don't use my ac because it doesn't work. but if i am able to get it to work i would like to be able to use it without my car shutting off.
    <a href=\"http://www.cardomain.com/id/ohmygoth\" target=\"_blank\">http://www.cardomain.com/id/ohmygoth</a>
    Re: ac turns car off
    every time my cell phone rings my radio turns off and on...
      Goth, maybe your a/c compressor has seized
        does sound like your compressor. if that stops moving then it might hold up your belt. what year is your car?
        everyone says that car can run with out the belt attached, but i kind you not, if my belt isn't on my camaro isn't even going to crank over.
        get someone to play with the a/c while you look under the hood. what do you see?
        WAWA-A-HOLIC
          the car should run without the belt.. the only thing the belt drives is the water pump, AC, alternator, and power steering pump
            lol i know. i kid you not my car WILL NOT turn over with out a belt. and the only thing my controls is the alternator and th epower sterring pump since i have an electric water pump and did the a/c delete
            WAWA-A-HOLIC
              maybe its some safety thing as to not damage anything if the belt breaks
                yeah who the he!l knows
                WAWA-A-HOLIC
                • Andy H
                  Transmission removal help!!
                  by Andy H
                • 2.8 Bird
                  Abs inop
                  by 2.8 Bird
                • fishin
                  by fishin
