Turn Signal Sticking - FirebirdV6.com/CamaroV6.com Message Board
  • Turn Signal Sticking
    Alright, I've tried searching for this, but all I could find was problems with the bulbs and stuff. All my bulbs work fine, and the blinkers work quite well. However, when I put the left signal on, it stays on until I turn it off, even when I turn the wheel. When I put the right signal on, it turns itself off as soon as I turn the wheel instead of when I recenter the wheel. Any help on this would be great! Thanks.
    Proud Member of the Fightin Texas Aggie Class of 2004! WHOOP!
    any help? or am I just stuck with a messed up blinker?
      usually when they stick that means that your lights are almost ready to go out, it is like a warning signal. Do they blink sometimes or is it stuck on every time?
      http://www.bowtiev6.com/
        No...the lights themselves blink. The problem is with the switch on the steering column. I can turn either direction on, and it works fine. However, when I make a turn and the switch should automatically turn off, the left one never turns off and the right one turns off as soon as I turn the wheel instead of when the wheel is recentered. I hope this explains it a little better. If I turn the blinker off automatically, they still work fine. It's just the steering column or something like that.
          its probably the turn signal cam in the steering column needs to be adjusted or replaced so that would involve taking the steering wheel off.
          1990 Firebird 3.1 T-Tops<br />Flowmaster exhaust<br />Kenwood MP 825 Deck<br />4\" Rockfords w/ tweet in dash plate<br />3 Way 6x9 Rockords in rear sails<br />1970 Camaro 350
            6 days ago
