what is the thorttle postion sensor and what does it do
i have a question
Re: i have a question
ok well the reason i ask is because when ever im in my car and lets say im going 30 mph my cars rmp go crazy jumping from 2 to 3 back to 2 and so on but if i let off the gas or press the gas it stops. and it only does it when i stay at one speed for a certain amount of time. some one told me it sounds like the tps what do yall think
Are you just cruising and it doing that, constant speed with foot on pedal? I dont think its your tps, how often was your last tune up? Does it seem like its not running as good as it use to.
edit: im pretty sure your tps (if it was bad) would affect how it runs right after start up. If its your tps, your car would rev up and down after start up. If you put it in reverse, does it act like it takes off very fast? (hard to stop) Im am also pretty sure the trans wont up shift and downshift because of the road. It should only do it when the rpms change.Last edited by bcraig; 08-27-2007, 12:02 PM.Check out my car on cardomain.com!!! <br /><a href=\"http://www.cardomain.com/member_pages/view_page.pl?page_id=844739\" target=\"_blank\">http://www.cardomain.com/member_pages/view_page.pl?page_id=844739</a>
Originally posted by bcraigAre you just cruising and it doing that, constant speed with foot on pedal? I dont think its your tps, how often was your last tune up? Does it seem like its not running as good as it use to.
it only does it when im at a constant speed with foot on the pedal and it doesnt last very long my 20 sec but it will do it at any constant speed. i just had a tune up the car run perfect expcet for that. no its drive fine in reverse.
Originally posted by kristenmaybe a maf sensor.
don't think that it's the tps. that would screw with your idle when your say...slowing down at a light or stop sign. could go from 800 rpm's down to say 400. and pick right back up. but i dont' think at a constant speed.
Originally posted by Kronic Budzsorry to break it to you, but it might be your transmission slipping. Or your timing is rediculously off. try a tranny flush if u havent done one for a while.
by DongrossmdI’m new. I actually don’t own a Camaro or firebird. I do have a 2000 Camaro 3.8 fly by throttle and 4l60e. This is installed in a 1980 Triumph TR7...4 days ago
by DoodlerHi, everyone. We bought a 97 base model convertible Camaro and someone broke the motor ... Lights were blinking on the dash and that someone ignored the...4 weeks ago
