Oil Change Light - FirebirdV6.com/CamaroV6.com Message Board
Oil Change Light
  • #16
    "This is why it comes on...
    It is due to a PSID (Pressure per Square Inch Differential)switch being triped. I see them on a few peaces of air craft suport generators and hyd. test stands I work on."
    I'm sure that's how they do it, but it's not how GM does it.
    "Why would they make an ECU engine rev count down when they could use a $3 switch to tell you when the filter is getting clogged."
    Because they're trying to figure out when the oil is worn out, not when the filter is clogging. On a car the oil goes before the filter does. On the equipment you're talking about, it may be the other way round.
    2000 Firebird convert, chameleon/tan, M5, Y87, TCS, BMR tower brace and panhard, KBDD sfcs, 245/50-16 GSCs
    • Manimal
      Coil springs
      by Manimal
      3 days ago
    • Manimal
      Newby here
      by Manimal
