OK, on the rear of the window, where it comes to a point, is nowhere near the weatherstripping on my car. I've got a site up that shows me how to adjust the window, but it doesn't look like any of them will pull the window in towards me. They have adjusting the window parallel to weatherstripping (seems like it would be the pitch of the window), and adjusting the window forward or rear (seems like it would be the angle of window). Those are the only two that seem to me like they might be what I want. Does anyone else have this problem? If so, how'd you fix it? Which of these do you guys think will fix it? Hoping to try them out this weekend and figure out.
Window adjustments
Re: Window adjustments
where are these sites your talking about? I need them :)
I believe the window going forward to back should solve the problem, if it's that far forward, the window can push itself into the mirror triangle and be too far forward. My window track is incredibly loose and right now, with my door open, i can pull back on the window and have it move several inches and then fall limp toward the car.. Need a new window motor again as well. this one lasted a good 8 months..:mad:
http://shbox.com/1/adj_window.html
And I'll check out the door this weekend Kristen. Never even thought of that, thanks.~97 3.8L V6 Camaro~
A few things
Only Member of Team Hooker?!?
I think I have the same issue. The driver side window is about an inch away from the lower half of the vertical weatherstrip. I tried the adjustments on that page awhile ago and although it helped with other issues, I could not get that gap closer.
It's a pain 'cause when I wash the car, if not careful, water will seep in. When I drive with my window up, i can hear the wind right behind my left ear, etc...
I'll be interested in knowing the outcome.
by DoodlerHi, everyone. We bought a 97 base model convertible Camaro and someone broke the motor ... Lights were blinking on the dash and that someone ignored the...3 hours ago
