Hey, my fog lights burned out the other day and I bought replacement bulbs, to change the bulbs I unclipped the plastic clips on the sides, and unscrewed the torx screw on the top. Then I continued to replace the bulb, but when trying to put the fog light assembly back in I have found it impossible to put the inside clip back in, due to the lack of space. I was hoping someone would kno a good trick.
Fog Lights
If you are talking about the 93-97 Camaro fog lights, you can try separating the side clips into two pieces. If you remove the center plug from the outer housing, you can insert the housing first and then push the plug in. It makes the piece shorter to try and fit within the confined space. If you can't fit it that way, you can also get at the brackets from behind by removing the lower clips on the bumper.
