Won't start - FirebirdV6.com/CamaroV6.com Message Board
Won't start
  • Won't start
    So i was driving in traffic on the freeway (stop and go) and the car gave a little shake and died. it wouldnt start at first but after a few it started up. I made it about a half of a mile and it died again. I then pushed it off of the freeway and since it was low on gas i went and got some and put it in but once it started after about 1 min. it shook and died again. It gives me 3 codes all pertaining to the O2 sensors. p0131, 137, & 151. after it was towed home i waited till the next day to mess with it but it would no longer even start up. i fell like it must be something to do with the fuel because when i try to start it i get no smell of fuel even when im pumping the gas. you would think you would get the flooding smell right? please someone help so i can sell this car as i just got a SS the same day it died.
    btw it has 78,000 on it.
    Re: Won't start
    I'm gonna take a shot since no one else has... but I'd say your car is running too lean and perhaps you should replace the map and o2 sensors
      Re: Won't start
      i forgot to say that i think i have a bad lifter or something also because my car is making a funky noise when i was able to start it for about the first 10-20 secs. along with a broken bolt on the exhaust manifold. small leak for the first 10 secs but goes away also.
        Re: Won't start
        thanks for the response! glad someone did to give me an idea. hope some more help comes. but why do i not get a fuel smell when i pump the gas? does the map have something to do with this. also 2 of the o2 sensors are new so there is no way it could say all three are bad right?
          Re: Won't start
          sounds like your fuel pump went bad to me, get a fuel preasure gage and check it. I bet that is your problem
            Re: Won't start
              Re: Won't start
              i now believe that it is the fuel pump. i cannot hear it prime when i turn the key. i found the valve to the fuel lines under the hood and when i pushed it in there was no pressure in the line. also i cannot believe that the pump cost 450 dollars. does anyone know where to get it cheaper maybe online as i am selling this car when it is running anyways.
                Re: Won't start
                what kind of car do you have? year? engine size?
                2000 Camaro 3.8 v6 M5
                Flowmaster 80 series muffler, B&M ripper shifter, SLP grille
                  4 days ago
