SES Light - FirebirdV6.com/CamaroV6.com Message Board
SES Light
  • SES Light
    Well my SES light came on again today, and the results are as follows:
    P0446
    Definition: EVAP (Evaporative Emission System) purge/vent solenoid circuit condition.
    Explanation:
    The solenoids and system wiring are monitored for opens or shorts
    Probable Causes,
    1 - Purge or vent solenoids defective
    2 - Check connector and Wiring
    3 - Fuel Saturated vapor canister
    4 - Failed EVAP Vent Solenoid
    Ok I know my car has been running rich lately because when I start it up for the first time for the day i see a little bit of black smoke coming out of the exhaust pipes, however I have no CLUE as to what this code means, so PLEASE all info and help is appreciated so I can see what the best route to go is. Thanks!
    Jeff
    Re: SES Light
    it could be 1 of 2 things. the purge valve which is right above you egr valve(held in with one screw) then there is the evap canister. if you have a 93-00 your canister is behind the black plastic panel on the driver side re wheel wel. if you have a 01-02 then the canister is on top of your gas tank. yes the whole tank needs to be droped.
    WAWA-A-HOLIC
      Re: SES Light
      hmm, well about 8 months ago i had a shop replace my exhaust and fuel pump, they obviously had to drop the tank for this. Any chance they could have screwed that **** up while they did that?
      Also, whats the severity of this?
        Re: SES Light
        little bit of gas milage. how long ago did the light come on? a line could be loose. what year is your car?
        WAWA-A-HOLIC
          Re: SES Light
          it came on yesterday, its a 2000 and i have noticed my gas mileage at only about 240 miles per tank.
            Re: SES Light
            i would start with the purge valve. put it in, be careful. if it doesn't fix it take the new one out and put the old one back in. return that part. then try the canister
            WAWA-A-HOLIC
              Re: SES Light
              if i had ANY idea how to do this i would? lol
                Re: SES Light
                i will take a pic of the purge this afternoon for you.
                WAWA-A-HOLIC
                  Re: SES Light
                  Ive been waiting 2 months for this picture kristen...where is it?!!
                    Re: SES Light
                    Hahahah! "This afternoon" means This late november.
                    TEAM C6V6
