When I begin to reverse at any speed other then very slowly I hear a scraping/cracking type of sound coming from the front end. It's almost like the sound you hear when you go to far past the parking concrete pillars and the air dam hits it. Very strange sound. Any ideas on what could be causing it. I look all around and nothing is touching or even coming close no matter if the wheels are turned or not. Its only recently been happening the last month or two. I just want to make sure nothing is seriously wrong. Any suggestions.Thanks.
possible reversing problem
1994 Camaro<br />3.4L V6 Automatic<br />K&N FIPK&Gold Oil Filter,Ravin Performance Exhaustw/Dynomax MandrelBent3\"I-Pipe&S Pipe&Catco 3\" HiFlow Cat.,ASP Crank and High AMP Alternator,U.D. Pulley Set, Bosch Spark Plugs and Oxygen Sensors, Taylor Wires, B&M E.ShiftPlus, 160 thermostat,Zexel Torsen L.S.D., CSI Remote Mount Electric Water Pump & Temp. Controller & Flex Hoses, ALM. Drivshaft, Diamond SubFram Conn.<br />COMING SOON: 350 or 502 RAMJET ENGINE & Big Block Hood<br />NJ V6 F-Body Club<br /><a href=\"http://tristategm.com/NJFbV6/\" target=\"_blank\">http://tristategm.com/NJFbV6/</a><br />Street Lethal F-Body Association <br /><a href=\"http://www.slfba.com./index.html\" target=\"_blank\">http://www.slfba.com./index.html</a>Tags: None
