My car is losing power!! - FirebirdV6.com/CamaroV6.com Message Board
  • My car is losing power!!
    hey,i have a 1999 camaro,and 3 days a go i did a burnout for less that 30 seconds,and at night i drove the car but the voltage meter was on the red dots,so i went to autozone and told me that i had to get a new battery and i did,but yesterday i was driving with the new battery and the battery voltage is still on the red dots,i really dnt want the new battery to drain..i really donno wut to do,could it be the alternator ???
    Re: My car is losing power!!
    With the engine running at idle, measure the voltage at the pos and neg battery posts with a Volt/Ohm meter. Proper voltage should be from 13.5 to 14.5 volts.
    If your voltage is proper then you have an indication problem (faulty gauge)
    If your voltage is not correct it could be:
    - bad grounds,
    - faulty battery cables,
    - bad field wire to alternator,
    - alternator failure (worn brushes or failed regulator, diode trio, bridge rectifier....etc.)
    Chances are if you just replace the alternator you will fix your problem. But there is the risk that it is one of the other items listed above.
      I had that problem. Loose connection from alternator to battery can do that. Check all of your connections.
      09 Nissan 370Z MB M6 Sports Package
      www.the370z.com
        I'm on my third alternator in my '99. That's likely the problem.
          :eek:
          You either:
          - drive a hell of a lot o' miles
          or
          - you buy cheap alternators
          or
          - you seriously overload you electrical system
          My 99 still has it's original alternator, but I rebuilt it myself:naughty:
            my 99 GPGT still has it's origonal alt.... of course I've just jinxed it now. crap
            2013 Ram 1500 Big Horn
            94 comero 3.4
              thxx guys,i really donno if im gonna make it home from skool right now,but imma give it a shot,,i think im goin to autozone and see if the problem is from the alternator and i really hope its not coz the car has only 68000 miles it
                Originally posted by CDNFB
                :eek:
                You either:
                or
                or
                AC Delco isn't cheap. However, the first one went out when I went to the drag strip, and the second one went about 3-4 months later when I was screwing around with my buddy on the interstate. Third one is still running strong. Could have just been a dud.
