Just came from the shop..
My security light kept turning on, and i wouldnt be able to start my car, sometimes an hour at a time. The light would go off even randomly while I was driving. The situation was getting very annoying.
After doing reasearch on this board, and visiting shops in Brooklyn, NY i concluded the problem was the damaged security cable inside my stearing column.
If you experience this problem, I cant stress it enough, do NOT! visit your pontiac dealership!
They know exactly what the problem is, but they will tell youll have to replace the whole stearing
wheel security mechanism, and get new keys. They will charge you $400+. DONT DO IT. Go to few Alarm places around you and shop around, they PASS II problem is very very common.
I would recommend you shop around and visit few local alarm places, even some mech shops, and speak to the ppl there...and see if they are experienced with this problem... thats what i did..
I fixed the problem for $120, its a lot, but its the cheapest one i could find and i needed it to be fixed fast. After being stranded few nights ago in the cold, trying to start the car.. i got fed up.
The problem is not always a damaged security light. Before you spend money on fixing this problem, clean your keys, it could be the dirty resistor on the key. But you know you have a problem when it goes off while driving!
Also if the problem is in the FACTORY security system itself, and not in damaged security wire, you can deactivate it for $100 or so, ask your mechanic for more details..
Good luck.
[ October 22, 2002: Message edited by: nyclaidback ]</p>
Good luck.
