when i open my door in the morning y car will make a few ticking noises before the door ajar dinging sounds. then i put the key in and go to start it and it wont start. it will tick a little and then start. it seems to be coming from the passenger side of my dash like behind the glove box. it only seems to do this in the winter time when its like 45 F or lower. nothing in the summer. it makes the same ticking noises as when the battery is dead. think its a relay but haven't looked into it. once the car has been started it is fine the rest of theday, but when it gets cold over night its almost like the relay or whatever it is clicks and warms up before you hear the door ajar bell. thanks guys
car makes electrical tick noises when cold
96 Camaro 3.8 A4 Basemodel: 8 mm wires, Shift Kit, Hollowed <br />Cat(o2 sims), RKSport exhaust, IAT 5.6K resistor, Home Depot CAI<br />>>>15.375 @ 89.27<<<NEW BEST TIME <a href=\"http://www.cardomain.com/memberpage/552491\" target=\"_blank\">http://www.cardomain.com/memberpage/552491</a>Tags: None
i wonder if its a 96 thing or something. sounds weird though doesn't it. the dealership said he would keep it overnight with the windows down so it would definetly freeze. then crawl inside under the glovebox and have someone open the door to see where it might be coming from. i havent tried this but will soon. urrrrrgggggg96 Camaro 3.8 A4 Basemodel: 8 mm wires, Shift Kit, Hollowed <br />Cat(o2 sims), RKSport exhaust, IAT 5.6K resistor, Home Depot CAI<br />>>>15.375 @ 89.27<<<NEW BEST TIME <a href=\"http://www.cardomain.com/memberpage/552491\" target=\"_blank\">http://www.cardomain.com/memberpage/552491</a>
try tightening the wires against the battery96 Camaro M5. Dark metallic gree (?dont know the offical color name)<br />Home made Intake :: Headers, 3inch headers back to Flowmaster muffler :: spec stage 3 clutch Now installed, waiting for 3.42\'s and LSD next month<br /><a href=\"http://photobucket.com/albums/y192/RiceEatingCamaro/?action=view¤t=newcar.jpg\" target=\"_blank\">My Car</a> <br /><br />Totalled Car.<br /><a href=\"http://bellsouthpwp.net/s/k/sk8er305/\" target=\"_blank\">96 CamaroRS</a>
they are tickened and clean. i even scraped the battery terminals to expose new and uncorroded metal. connections are great. remember it only does it when the car is cold. and the headlights will turn right on. turning the key on is when i hear the ticking noises the security light blinks once per tick. when the ticking stops the security light stays on like usual until your car is on. it ticks when i open the door too. the ticking will stop in a few seconds and the the door ajar bell will sound and dome lights come on.96 Camaro 3.8 A4 Basemodel: 8 mm wires, Shift Kit, Hollowed <br />Cat(o2 sims), RKSport exhaust, IAT 5.6K resistor, Home Depot CAI<br />>>>15.375 @ 89.27<<<NEW BEST TIME <a href=\"http://www.cardomain.com/memberpage/552491\" target=\"_blank\">http://www.cardomain.com/memberpage/552491</a>
hey guys, you know how the radio and everything works until you open the door right. i wonder if it is that little sensor thing. im almost positive it is now that i think about it. lets all do some research on the security-dooropen accessory sensor thing. lets get this thing figured out so we can go on without ticking in our lives. he he96 Camaro 3.8 A4 Basemodel: 8 mm wires, Shift Kit, Hollowed <br />Cat(o2 sims), RKSport exhaust, IAT 5.6K resistor, Home Depot CAI<br />>>>15.375 @ 89.27<<<NEW BEST TIME <a href=\"http://www.cardomain.com/memberpage/552491\" target=\"_blank\">http://www.cardomain.com/memberpage/552491</a>
i have a 96 too. does it only happen on 96's?
ahhhhhhhhhh, i hate it. it happened the other day to me when it was wicked cold out, and the damn car clicked like a feind, i put the key in the ignition, turned it to start, and the clicking stopped and the car didnt start.
then the car started when i tried it again, and died immediately.
then it would just crank and misfire for the next like 2 minutes.
finally it started.
pisses me off. rrgh!
we gotta find this out.
<blockquote>quote:</font><hr>Originally posted by OrangeAndScreamin:
That would be the vats messing up, probably the sensor on your keys has worn down. Not getting a good connection<hr></blockquote>
it clicks before the key is even in the ignition. its the door chime clicking, and then the car wont start.
not to be stupid or anything but what is the BCM and if you use none common acronyms anymore could you please define, at least once so i remember. anything to do with cars will never be forgotten by this mind.96 Camaro 3.8 A4 Basemodel: 8 mm wires, Shift Kit, Hollowed <br />Cat(o2 sims), RKSport exhaust, IAT 5.6K resistor, Home Depot CAI<br />>>>15.375 @ 89.27<<<NEW BEST TIME <a href=\"http://www.cardomain.com/memberpage/552491\" target=\"_blank\">http://www.cardomain.com/memberpage/552491</a>
wonder if its a recall????96 Camaro 3.8 A4 Basemodel: 8 mm wires, Shift Kit, Hollowed <br />Cat(o2 sims), RKSport exhaust, IAT 5.6K resistor, Home Depot CAI<br />>>>15.375 @ 89.27<<<NEW BEST TIME <a href=\"http://www.cardomain.com/memberpage/552491\" target=\"_blank\">http://www.cardomain.com/memberpage/552491</a>
You guys sure it's just not the battery being weak from the cold, when the weather is in the 20's my car is slow cranking and when it's below 20 it sometimes takes a couple times to start it. And everytime my battery is weak or if I'm reconecting my battery it'll make that clicking noise. I'm thinking it is just the cold causing the battery to be weak, and the door ajar bell is using what little juice that the battery has.1999 Silverado- Bagged, colormatched and rollin on stock chrome 16\'s<br />Make love not war, hell do both, get married
by ssms5411Had to be evacuated Monday again after a fire was going on the hill behind us. Only 3-4 hours, they did a good job getting it under control. Especially...1 week ago
by RPDRed6Up for sale is my 2001 Chevrolet Camaro 3.8 in need of some TLC and help. I’ve owned this vehicle the past 18 years (since 2006) and it’s been very...4 weeks ago
