i have iced my intake down too, Im jsut smarter and leave them sitting in the pits and not in the back of my car letting water fall onto the track
FREE TRACK MODS! TELL ME SOME!
The thing is... it doesn't leak... I have checked it before. And when I went out to check I forgot but I keep rags in there as well and they block the hole anyways... Even if they were still not in there I would be confident that I amd not pouring water down the track.
And you will probably say I am making up the stuff about rags, but reason they are there, I keep them in there to wrap the points where the spare rubs against the metal. Nothing more annoying then a slight sqeuking noise from the trunk do to the rubber of the spare rubbing against the metal...
and actually I do know what its like to see a f-body loose it on the top end, happened to a friend of mine 2 weeks ago. wrecked his 98 Silver convertable LS1 at the top end, we think oil or some other fluid.
I coudl understand telling me about it if I was some newbie to drag racing... but I have been doing it for a few years and have seen the no-no things to do at the track.
-don't drive through burn-out box(drive by and reverse back to if necessary)
-don't run AC, run heat to trip cooling fans(big problem at my track, since its in FL and near a swamp, AC condenses and drips on track
-make sure your sh|t is running right, everyone hates it when a car breaks down for a stupid reason, or if we have t wait for the cleanup of fluids you are shooting everywhere.
-Don't turn around on the dragstrip if you miss the first turnoff there are more down at the end(antoher problem at my track)
<blockquote>quote:</font><hr>Originally posted by Drone51:
and how is that hes saying hes not leting water on the track when there is no way he is preventing it. IT IS GOING TO HAPPEN PERIOD
and dont be mad cause you cant even spin your tires when its wet out if you had a fast car you would understand
have you ever seen a high hp car hit the wall topend, and why because some stupid v6 owner was trying to run a 14 ha that would piss me the **** off<hr></blockquote>
dude...why are you even here??1997 Camaro 30th Anniversary...M5, chrome 16\" 5-stars Goodyear 245/50R16<p><a href=\"http://members.cardomain.com/issycamaroman\" target=\"_blank\">http://members.cardomain.com/issycamaroman</a>
<blockquote>quote:</font><hr>Originally posted by White95:
what if you buy another spare tire and use the spares in front instead of your stock wheels? They're smaller, weigh less. Just an idea.<hr></blockquote>
hey all this is my first post anyway.
Why do that the tires arnt rated at more than 55mph and there steel rims. Just get some custom 13" alluminium or magnesium($$$) rims for the front end sure it might cost more but hey whatever your money not mine.
[ January 26, 2004: Message edited by: Gargoylebrother ]</p>\"Professionals are predicable, but the world is full of dangerous amatures.\"
<blockquote>quote:</font><hr>Originally posted by 99redcamaro:
25 psi on the rear tires
35 psi at front<hr></blockquote>
I run 45/30 I start high on rears and drop it, I seem to hook pretty well aorund 30.
45psi front ain't that bad, becuase that is what I put them at while hot(on way to the track), when the cool they drop a few lbs...
those spare tires are only rated at 45-50 mph.96 camaro auto base model<br />slp cai<br />pacesetter headers<br />flowmaster catback<br />35th anniversary ss wheels<br />richmond 3.73<br />98+ ss spoiler<br />hypertech 160 degree thermostat<br />transgo shift kit
not to flame you or anything, but two things.
1. page two says what you said about the spare tires
2. the thread is 1 year and 3 months old.
although i read through it again. maybe someone by now will add a "new" idea for a free mod.
but hey, at least you are using the search instead of just being lazy and asking questions everyone has asked a million times. mad props to you. [img]graemlins/rock.gif[/img]96 Camaro 3.8 A4 Basemodel: 8 mm wires, Shift Kit, Hollowed <br />Cat(o2 sims), RKSport exhaust, IAT 5.6K resistor, Home Depot CAI<br />>>>15.375 @ 89.27<<<NEW BEST TIME <a href=\"http://www.cardomain.com/memberpage/552491\" target=\"_blank\">http://www.cardomain.com/memberpage/552491</a>
LOL this is the second ancient thread thats randomly gotten pulled up in the last like 2 days.-Kevin<br /><a href=\"http://heinz.no-ip.com/Car%20Pics/IM000117.JPG\" target=\"_blank\"><b>\'96 White Camaro RS M5</b></a> <br />GTP Shortblock - T3/T4 -6psi Intercooled<br />Open Downpipe
Nothing, you have no power steering or water pump. Its only used just for the drag down the strip. The battery supplies the power to fire the spark plugs, suprisingly...-Kevin<br /><a href=\"http://heinz.no-ip.com/Car%20Pics/IM000117.JPG\" target=\"_blank\"><b>\'96 White Camaro RS M5</b></a> <br />GTP Shortblock - T3/T4 -6psi Intercooled<br />Open Downpipe
tThat is because a spare isn't a skinny, it's a spare they aren't designed to go faster than somewhere around 55-65, plus they aren't designed to support that kind of weight (having two skinnys) they are just basically a crutch. as for driving without a belt i would seriously consider finding a small belt to at least spin that water pump.
Try pulling the rear driver side spring isolator (put reinforced hose on the top coil) this should take weight out of that side making the two sides more even when the car is torqueing at launch (air shocks or air bag is a better way to do this).
