need help with two problems - FirebirdV6.com/CamaroV6.com Message Board
  • need help with two problems
    Hi everybody I have one problem and one potential problem happening. First my car is an automatic and after startup when I shift out of park and into drive and apply the gas my car chugs and lurches like it has a bad misfire, but this only happens for about 3 seconds and then it runs fine. I have no idea what this could be as the car runs well after this happens. Secondly, after i turn the air conditioning off sometimes, and sometimes when it has not been on at all, air blows from under the dash as if the air was set to blow on my feet, even though it is turned off. Does this happen to anyone else? Thanks alot.
    Re: need help with two problems
    does the air blowing under the dash come out strong or as if it was barely on?? If its barely blowing then thats normal.
      the air problem happens in EVERY car, if you turn it to a hot setting, the air will come out hot.
