back story... car was leaking coolant from radiator(way up front away from radiator. Pulled cap, found Dexcool, Jello. I pulled the thermostat, Flushed system hoping to clear crap out before I put in new radiator.
While driving car stalled out, but did not overheat. towed home, pulled radiator, water checked it, it definitley is leaking, I throw a new one in, change oil(looked fine but was getting close to 3k miles)
Filled car up with fluids. Start it up, and I dumped maybe a quart of coolant out the exhaust, car is making knocking noise(sometimes goes away, especially iwth clutch in or out) Also getting puffs of smoke/steam out of open radiator cap. Car is dead cool.
So I drained the coolant(trying to see if it runs fine with no coolant, maybe just a head/intake gasket.)
Car idling like crap, making noise... white smoke out tail pipe. Trying to work coolant out...
FIRST ISSUE
but whats wierd monitoring the misfires with HPT...
they seem to move... first they were focused on cylinders 3, 4, later went to just #6 disapear and reappear, car runs rough whole time and putting out white smoke(coooking off coolant in motor)
What would cause that? They are not even near each other?
Still hearing the knocking, less issues that it warmed up, but knocking louder.
What do you think would cause this? not even the same bank? did I blow both gaskets? I mean seems unlikely.
FIRST ISSUE
