Guys im gettin so discouraged......i cant run anything but premium in the car w/o it pinging and im a 96 3.8.....ive tried everything i know to do ....Fuel Filter,plugs,wires,seafoamed it,pcv valve,new air filter. I`m just getting all around discouraged with the car....its really going downhill and i dont know what to do. Please try and help me get my baby running good again. also i have 136k on the clock
Sigh..Pinging.........help plz
What temps are you running when you get predetonation? Tried a lower temp thermostat and a coolant flush and fill?
Is it an occasional ping or does it do it all the time?1994 Firebird 3.4<br />15.65 @ 86.8<br /><a href=\"http://www.funkz.net/firebird.htm\" target=\"_blank\">funkz.net/firebird</a><br /><a href=\"http://mywebpages.comcast.net/funkz/timeslips.htm\" target=\"_blank\">Timeslips</a>
how long have you owned this car? is it possable some one could have programed it for higher premium gas? Is this a stock engine, no high compresson? There sould be no knocking at all, im guessing its a computer problem.<a href=\"http://www.cardomain.com/ride/2245261\" target=\"_blank\">http://www.cardomain.com/ride/2245261</a> Green 1997, 105k, all stock except for Z28 front springs, Air shocks in the rear, home made coolant recovery tank, home made battery hold down.
Were the old plugs white when you changed them? Is it running lean?1994 Firebird 3.4<br />15.65 @ 86.8<br /><a href=\"http://www.funkz.net/firebird.htm\" target=\"_blank\">funkz.net/firebird</a><br /><a href=\"http://mywebpages.comcast.net/funkz/timeslips.htm\" target=\"_blank\">Timeslips</a>
with 8k it should look fairly clean and gray, but not white. White means your running kinda lean. You might wanna try replacing you o2 sensors. My car runs great but im starting to get bad gas milage, about 22 hwy, im going to replace mine and see what happens.<a href=\"http://www.cardomain.com/ride/2245261\" target=\"_blank\">http://www.cardomain.com/ride/2245261</a> Green 1997, 105k, all stock except for Z28 front springs, Air shocks in the rear, home made coolant recovery tank, home made battery hold down.
A dirty MAF wire will make you run lean. You need to be very careful when cleaning it so you don't damage the thin sensor.1994 Firebird 3.4<br />15.65 @ 86.8<br /><a href=\"http://www.funkz.net/firebird.htm\" target=\"_blank\">funkz.net/firebird</a><br /><a href=\"http://mywebpages.comcast.net/funkz/timeslips.htm\" target=\"_blank\">Timeslips</a>
I wasn't pinging, I was getting a backfire with new iridium gm plugs. My dad is a gm tech, did a scan and it showed very little misfire, but come saturday with the scanner plugged in I got it to missfire in 1rst and 2nd near 4500rpm and the tech2 show missfire on a specific cyclendar. We ended up replacing the 1 spark plug and a new set of ac delco wires. that fixed my problem, I had already done all of the other matainace items like you have just done recently.
And everyone clean the coil pack tips with a wire brush, it could save you some money.255/50R16 Tires, Pioneer Deck, Pioneer 4 Way speakers, PPI Amps, JL subs, Spec Stage 3 Clutch, Optima Yellow Top
Could be. Clogged cat makes the exhaust overheat, could cause the pinging. Didn't realize you had a performance problem before since you said it didn't have a problem when using premium.1994 Firebird 3.4<br />15.65 @ 86.8<br /><a href=\"http://www.funkz.net/firebird.htm\" target=\"_blank\">funkz.net/firebird</a><br /><a href=\"http://mywebpages.comcast.net/funkz/timeslips.htm\" target=\"_blank\">Timeslips</a>
