P.O.S is pissing me off - FirebirdV6.com/CamaroV6.com Message Board
  • P.O.S is pissing me off
    over heating is an on going process
    i changed my therm and water pump maybe 1500 miles ago
    flushed the radiator and bled the air
    heats up to around 260 then drops to 230
    back and forth dont know whats going on HELP!!!
    Re: P.O.S is pissing me off
    Does your car still have the plastic deflector under the front bumper? I know from personal experience that if it get knocked off or removed the car will overheat exactly like you're describing. FYI 260 is when the fans kick on and 230 is when they go off
      so your telling me a little plastic thing that has nothing to do with coolant is making me overheat
        yes, coolant isnt always the reason cars overheat
          i took that b**** off like 4 months ago :rant:
            Hi,don't get all flustered guy if you are not a mechanic don't take it on see a mechanic,Firstly is the car loosing coolant? Secondly are the fan or fans coming on? Do the Fans spinning at the speed they usually spin at? Is your Coolant Temperature Sensor working correctly or do you have an aftermarket Water Temp by Automoeter that you can check to see if both are working together or close to one another?You have to do more checks that is how you analyse problems.
              why would you take it off?
              edit* just about everything they put on the cars are needed in some way, or they wouldnt put them on
                haha in my town they dont know how to make streets theres nasty bumps all over the road and one day i heard somthing scraping and i looked under my car and it was just hanging there by 1 or 2 screws so i took it off
                  You need to go buy a new one and your problem will be solved. It's around $35 at the dealer. And yeah, I did the same thing you did for the same reason which is why I know how much a new one costs.
                    thanks guys
                      6 days ago
