how do i... - FirebirdV6.com/CamaroV6.com Message Board
how do i...
  • how do i...
    how do i get the pullies off the engine? does the tentioner pully come off cause i cant seem to get it off.
    and there is also one under the ac thing on the pass said of the car, does this thing come off, i cant seem to figure out how to get any of the rotating belt things to come off
    Re: how do i...
    remember things like the tensioner pulley "righty tighty, lefty loosey" doesn't apply. The thread is opposite a normal bolt. Hence why you couldn't get it off
    http://www.bowtiev6.com/
      Re: how do i...
      ok that explains that, what about the pully under the ac, i took the bolt out of it, but it looks like it is mounted on a bracket. tried to unbolt that bracket and nothing
        Re: how do i...
        and how do i take off the pully that is on the alt? is that also reversed?
          Re: how do i...
          ehh? they all go the same way
          the tensoin pully has coolant it you have to pull out on the bottom and then to the right
          www.turbov6camaro.com
          1997 3800 Series II Camaro
            Re: how do i...
            just get the bolt out and wach them from behind. they will pop right off
            WAWA-A-HOLIC
              Re: how do i...
              The bolts taht hold the tensioner assembly this is true but the pulley that is on tensioner had a reversed thread bolt holding it on.
              Originally posted by kala
              TEAM BLACK!!!
              parting her out
                Re: how do i...
                that alternator is best with an impact gun if u have
                1997 Camaro LS1 RS
                1994 Camaro - Sold
                1999 Trans am Vert - Sold
                A Few Mods....
                  Re: how do i...
                  indeed
