I swear my Automatic Shifts 4 times - FirebirdV6.com/CamaroV6.com Message Board
This topic is closed.
  • I swear my Automatic Shifts 4 times
    so mine is 99, 4 speed automatic. With 4 speed.. as you start driving, its suppose to change gear a total of 3 times to go up to the max gear.. right. Like this... from stop, you start driving. Gear changes ONE time to shift from 1st to 2nd. Then changes SECOND time to shift from 2nd to 3rd. And finally THIRD time to shift from 3rd to 4th.
    BUT... mine changes gear a total of 4 times.. yeas FOUR. One thing I also noticed.. when it makes the last change.. the rpm comes half way down comparing to other 3 previous changes.
    so whats going on? And no I am not crazy and yes I did pass my math in highschool [img]smile.gif[/img]
    on a different topic (and not to waste posting) what the max width of tire i can put on a factory rim. like.. will 275/40/16 fit on a factory rim.. whats the max i can go.
    Thanks and happy new year. [img]smile.gif[/img]
    Torque converter locking up. ;)
    2nd question: http://www.camarov6.com/ubb/ultimate...c;f=2;t=003367
    Matt
    1998 Mystic Teal Camaro M5
      hmmm.. if the torque converter is locking up shouldnt it give problem or something.. its runs smooth.. no shaking.. no loss of power.. no codes.. nothing.
        Torque converter lockup is normal operation. It lowers your engine rpm on the highway and saves gas.
        \'00 f-bird 3.8 M5 coupe, pewter metallic<br />Torsen LSD, Pro 5.0 shifter, Spec stage 1 clutch, Y87 muffler, aftermarket stereo<br />-more fun than the Oldsmobile it replaced...
          lock up and you should be happy,,,,it saves gas
            Isn't that an effect of overdrive? Using the engine to reduce RPM, rather than downshifting? Or am I just stupid?
              i think some cars came with 5 speed autos, i dont know what years, but i know ive seen them when i was looking to buy mine. May have been missprints, but i dont know
              [ January 01, 2006, 09:28 PM: Message edited by: BobbyZ72 ]
                the torque converter will lock up when the momentum on the output side becomes greater then the momentum on the input side, i don't know how to best explain it but you can look it up on wwww.howstuffworks.com its pretty helpful if your going to think swapping converters theres alot other cool car things on there too
                K&N air filter, Whisper air lid, magnaflow LT1 cat back, and magnaflow high flow cat, pacesetter headers, silverstars<br /><br />more to come soon<br />but for now im out of money
                  its a 5 speed of you count overdrive as a gear otherwise it is a 4 speed
                    This is an hilarious thread.
                    FOUR TIMES!!!
                    lmao
                    <b>99 Pewter Metallic Camaro</b><br />SLP Ultra-Z Hood, Shaved Antenna, !mouldings, Chrome Halos, Filled Factory Grill, Y2K 18 R 19 F, SLP Whisper Lid, (functional w/ Hood), FlowMaster American Thunder C.B, QA1 Coilovers, Kuhmo Tires.
                      2 - 3 - 4 - lockup
                      www.turbov6camaro.com
                      1997 3800 Series II Camaro
                        Just to set the record straight, GM powertrain [our transmission supplier] did have a 5 speed automatic for rear wheel drive applications, but it was NEVER used on our cars. They made them for BMW. I don't think the torque rating was high enough for us, not to mention it was more expensive to make.
                          thats ur overdrive i think
                            it is not the overdrive, overdrive = gear # 4, what you feel is the torque converter
                            try going down a straight pedal to the floor the whole way, it won't shift four times because the torque converter won't lock up, the momentum will never be higher on the output side of the converter like it would during daily driving
                              yeah, by the time u get to 4th ur gonna be going about 90 and i'm sure you'd rather take our word for it than try explaining that to ur friendly local law enforcement [img]tongue.gif[/img]
