window motor finally went up - FirebirdV6.com/CamaroV6.com Message Board
  • window motor finally went up
    well now went i put my window down it wont go up, so does anyone have any suggestions on the best motor to buy?
    K&N air filter, Whisper air lid, magnaflow LT1 cat back, and magnaflow high flow cat, pacesetter headers, silverstars<br /><br />more to come soon<br />but for now im out of money
    Autozone's window motor(s):
    SIEMENS_NEW
    # WL42014 LLT $54.99 ~~&gt;This is the one I bought when my motor went bad.
    CARDONE_REMAN
    #42-150 $49.99
    PARTS_PERFECT_NEW
    # MM1-42014 LLT $53.99
    They come with a warranty, and they work just fine for our f-bods.
    This is how to do it. ;)
      ok thanks alot
        also does anyone know the part # of that light that lights up the window control
          just pull out the bulb, take it to walmart and look for one that it looks like. I think pretty much anything thats the same size will work.
          <a href=\"http://www.cardomain.com/id/briansr\" target=\"_blank\">97 White Pontiac Firebird 3.8 A4</a><br />Mods- 2.75\" exhaust, Dynomax muffler, magnaflow cat, SLP CAI, Hypertech 160* thermo, Fan switch<br />Suspension-Kumho Ecsta 712\'s, 32mm/19mm sway bars<br /><br />Our Lady of Blessed Acceleration, don\'t fail us now. <br />-Elwood Blues
            the bulb is a #74
            1997 Camaro LS1 RS
            1994 Camaro - Sold
            1999 Trans am Vert - Sold
            A Few Mods....
              the site that hockeyman gave you is the one I used as well. I changed both of my power window motors just over thanksgiving. First one took a while just cuz I wasnt sure what I was doing. But the second door took maybe an hour to pop the door panels off, drill the hole, drill the rivets, line up and screw in the new motor.
              You use a 1/2" bit to drill the holes in the door and I think a 3/8" to drill out the rivets. If you need to know for sure I can go back and look. but all I did was pick a bit that was just about the same size as the screw I needed to use for the new motor.
              I also used the same motor hockeyman used. Its only been a few weeks, but they still work. Just make sure you tighten the screw/nuts. You only use 3 so if one is loose your door will rattle whenever you close the door :/
              As I said before I just did this so if you have any questions feel free to get ahold of me.
