Replacing spark plugs - FirebirdV6.com/CamaroV6.com Message Board
  • Replacing spark plugs
    Anyone know the best way to remove the spark plugs? Tight spot for people with big hands. And any suggestions for plugs for mostly stock?
    Re: Replacing spark plugs
    Lots of different length extensions, u-joints, and tons of patience. I found it was just trial and error. I used different length extensions until I found the one that worked best for me. I also have a Snap-on sparkplug socket with a built in u-joint which is a fantastic tool.
      I like AC Delco's.....especially there rapid fire's.
        I did all mine using a regular socket and 3" extension when needed. Like was said, the biggest thing you need is patience. Also, maybe it was just my car, as I seem to have a trend of things getting stuck together, but your wires might require alot of hard pulling to get off, just stick with it.
        Hope this Helps,
        Mike
          some of them are easier to get to from the bottom of the car as well
            Sometimes the breaker bar helps, long enough and small enough to get em loose
              wheel well or top/bottom with a swivel joint and a 3 inch extension. I personally went from top to bottom
              Car expresses who you are. If you have a ****ty car, you must be a ****ty person;)<br /><br /><a href=\"http://www.cardomain.com/ride/995979\" target=\"_blank\">http://www.cardomain.com/ride/995979</a>
                Hope this Helps,
                Mike
                Yep, basically what he said. Took out the rr two from bottom on driver's side and rr most one on the passenger side. The other 3 from top. Bought a new spark plug boot puller, but nothing worked as there was no leverage/room. I ended up using a flat head screw driver to get the boot off. Also have to take off manifold shields, starter shields. Took 4 hrs.
                I don't see rapid fires anymore, I went to AC Delco and they state a new replacement for the plugs, it's not platinum anymore...it's iridium now(NGK)!
                1999 Pewter Camaro M5<br />Y87 Performance Package, Sport Appearance Package, Diamond Clears<br />Factory SS Hood, Free Ram Air Mod, Whisper Lid w/ K&N Air Filter<br />CarSound Cat 94009, B&B Tri-Flo w/ Quad Tips<br />BMR SFC, BMR STB, KVR Blank Rotors, Hawk HPS Pads<br />Black Painted Calipers w/ CAMARO Decal, 245/50 Dunlop SP Sport 5000<br />20% Rear 35% Side Tint, Red Reflective Inlays, Invincishield<br /><b>Young girls avert their eyes, weak men tremble, Ford dealers faint.</b>
